DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Cooker 3.5kw cable size
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
  View previous topic :: View next topic
Author Message
deece
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 16, 2007 10:49 pm    Post Subject:
Reply with quote Thanks
Please help.
I have a new Bosch cooker which is 3.5kw. The existing setup is a single 2.5mm cable from the consumer unit to a double pole switch and then a thick flex to the cooker. The mcb at the consumer unit is 16amp. Will this be ok for the new cooker? Also the bosch manual states I should use a HO5 W-f mains connection lead. Is this a type of flex lead? and if so what does it basically mean?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 16, 2007 10:57 pm    Post Subject:
16A and 2.5mm^2 cable is fine.
It's not W is V V. It basically means a PVC insulated, PVC sleeved, flexible cable.
Back to top
 Alert Moderators
deece
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 17, 2007 8:17 am    Post Subject:
Thanks for the info Davy.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
How can i work out the size of cable for cooker? 12 760 Sun Apr 05, 2009 8:34 pm
cooker circuit cable size 4 3380 Mon May 15, 2006 10:52 pm
Cooker Cable Size 15 660 Sun Apr 05, 2009 4:49 pm
Electric cooker cable size requirements 3 3160 Sun Feb 17, 2008 10:03 am
Cooker cable size? 5 1420 Tue Apr 15, 2008 12:23 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
