Nosmo
Joined: 18 Jan 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Jan 18, 2007 12:31 pm Post Subject: gate valve stuck |
I need to turn off gate valve but it is impossible to turn even with spanner. Is there a way of freeing it ? |
namsag
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Thu Jan 18, 2007 2:21 pm Post Subject: |
If it`s that stiff don`t touch as it will prob snap in the closed position then it will definetly have to be changed... |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Thu Jan 18, 2007 2:31 pm Post Subject: |
Try undoing the gland nut round the shaft first - might help. |
EVER-PURE
Joined: 05 Nov 2006 Posts: 7 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Wed Jan 24, 2007 8:26 am Post Subject: Gate Valve Stuck |
Gate valves, need to be turned off and on every two or three months. Limescale may be onside stopping it fom moving, what you may need to do is tighten a little to dislodge the limescale, then try again to loosen the Gate Valve, if this don't work you may need to fit a new one. |
