DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing Tiled Window Sill with a Window Board
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
comfortably_numb
from United Kingdom
PostPosted: Fri Jan 19, 2007 6:11 pm Reply with quote
I have this bright idea of replacing the window tiles for window boards, Being the novice i am, i ring local merchants & tell him what i'm doing & can he supply the boards, no rpoblem he says pop down & i'll cut to size.
I proceed to remove the tiles & i am left with a bare window sill with 2 cut outs at the bootom of each reveal (i'm hoping this makes ense to someone). I pop down & pick up the boards, get them home & find they are an inch less in depth & also to thick to fit into the reveal "cut outs" either end.
Am i missing something here ?? because the shop didnt mention that the boards come in different depths & do i use the reveal "cut outs" .. if not, how do i get the boards to overlap each end ??
The window board also has a lip ... what is this for ??
Any advice i would be greateful for
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1294 times
PostPosted: Sun Jan 21, 2007 11:28 am Reply with quote
window boards should be cut 80- 100mm wider than the reveals to show 40-50mm past each reveal. these small returns should have their edges planed and sanded the same as the front bull nose to match.
m.d.f. pre primed boards can be sold in up to 5m lengths, and in widths of 225mm and 300mm. the 300mm wide board will deal with most wall cavity sizes. they are 25mm thick.
the machined tongue at the back edge of the window board would slot into a re-bated groove machined into timber windows only. upvc windows do not have this groove.
if the window board sits too high on the window then remove some of the material below and re-plaster the sill. you will also need to chase in the window board a little, into the reveal plaster. it always looks better if you skim the window board in.
Back to top
 Alert Moderators
comfortably_numb
from United Kingdom
PostPosted: Sun Jan 21, 2007 10:16 pm Reply with quote
thankyou
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Leaking tiled shower enclosure 21 39860 Sat Apr 01, 2006 4:51 pm
Tiled in cooker switch??? 6 660 Mon Feb 13, 2006 7:28 am
tiling over a half-tiled wall. 9 800 Thu Feb 02, 2006 8:59 pm
Help, tiled kitchen ceiling!!!! 2 360 Mon Nov 07, 2005 6:58 pm
Tiled Plasterboard Removal 4 660 Sun May 07, 2006 8:40 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
