Zanussi Aquacycle won't drain
20 Jan 2007
My washing machine is working perfectly except that I have to manually drain it whenever necessary during and at the end of cycles. The filter is completely clear, the draining pipe is too, and I've even checked the pipe leading out from the house. Any idea what could be causing this?
breezer said:
pump or its connections
Thank you. Any idea if it would be expensive to get repaired. The machine is almost five yrs old so it could make sense just to buy a new one.
Hi Bob,
I have the same problem, did you get yours fixed? was it exspensive and what was wrong with it?
could also be pressure switch (this is round at the top of machine & has a clear plastic pipe connected, which sometimes gets blocked).
cheers for the reply tommy it was the waste valve between the drum and the pump was blocked with a sock!!! all sorted now and back working again.
