t506
Joined: 22 Jan 2007 Posts: 2 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Mon Jan 22, 2007 8:06 pm Post Subject: olive repair? |
Ive removed my radiator, and the nuts were really tight and although i did use two wrenches to try not to damage the olive, it seems like i have anyway.
the whole thermostat valve now spins on the copper pipe, when i turned the heating on there is a fast-ish leak from the radiator connecting end of the valve and a very slow one on the copper pipe under the connection, the boiler has no water in it now I assume this is connected as when i turned the heating off i could hear the pipe sucking air in.
Can i repair it or is it time to admit defeat? |
Fluffster
Joined: 05 Jul 2006 Posts: 971 Location: London, United Kingdom Thanked: 2 times
Posted: Mon Jan 22, 2007 8:08 pm Post Subject: |
Copious amounts of plumbers tape for everything.
Pete |
loafer
Joined: 16 Feb 2006 Posts: 134 Location: Sheffield, United Kingdom Thanked: 0 times
Posted: Mon Jan 22, 2007 9:55 pm Post Subject: |
if the olive is dammaged or as I suspect, may have been damaged by overtightening (very tight nuts): try carefully cutting through the olive with a junior hacksaw. Then lift/prize off with a sharp slotted screwdriver. Take care not to nick the tube.
Reassemble with a new olive. PTFE around the olive (belt n braces) just in case. Tighten nut till you feel reasonable resistance and add a quarter turn. Better to slighlty undertighten initially. If still weeping, slowly and gradually tighten till leak stops. |
t506
Posted: Tue Jan 23, 2007 9:09 pm Post Subject: |
ok so the radiator is back on and the big leak sorted, now the pipe onto the manual control valve is leaking from the copper pipe, ive put lots of plumbers tape on but its still dripping slowly.
i havent turned the big bolt that connects it to the valve.
More plumbers tape?
Will silicone work?
thanks |
EVER-PURE
Joined: 05 Nov 2006 Posts: 7 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Wed Jan 24, 2007 10:31 am Post Subject: Olive Repair? |
What you should do is repeat what LOAFER had posted earlier, but you shouldn't need PTFE the Olive will be enough |
