Baxi Boiler Loud Clicking No CH
22 Jan 2007
Durham
Can anyone help with this problem please?
When trying to turn the CH on a loud clicking banging sound occurs. Has been getting worse over the last few days where the clicking would start off fast then get slower & slower until it would stop & the CH would come on. Now it just keeps clicking & no CH comes on. Thought the sound was originally coming from timer control panel but can also be heard from behind the fire.
I Got it wrong again dad!!!
mind you I would not mind either the bahamas or bermuda, beats the **** out of surrey in the ****iong rain
a back boiler
then i have no idea, I have had too many ciders to think
it is my night off :)
I will leave it to the other esteemed boyos
Someone once told me he had a Baxi Barbados boiler.
Behind flap on bottom of the fire where you get to gas valve for boiler etc . At the bottom right hand side just below the gas valve there is a small push in electric connection make sure this is fully pushed in.... I f when your boiler is making the noise it stops when you move this the chances are it it is a loose connection within this. Other than that it is faulty gas valve the noise is the valve chattering trying to open.............. This is based on you saying noise is from behind fire
Could be one of the newer electronic ignition bermudas. That would be the clicking sound before it fires up. If its not firing up it could be a faulty gas valve?
