DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
rusty radiator
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
diane1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 23, 2007 3:39 pm    Post Subject:
rusty radiator
Reply with quote Thanks
one of my radiators is really rusty at the end where you would bleed it. does this mean its about to fall to pieces really soon?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Tue Jan 23, 2007 4:07 pm    Post Subject:
difficult to say without seing how bad it is but ive an idea from seeing others like it.
if it does leak s***s law it will be when you are not at home and cant do anything about it. safest thing to do is get a new rad fitted.
Back to top
 Alert Moderators
diane1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 24, 2007 8:43 pm    Post Subject:
i thought so. this radiator is over 2meters long, im not sure you can get them that long anymore. is it a big job to move the pipes for a shorter radiator?
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Wed Jan 24, 2007 9:03 pm    Post Subject:
no need to do that in most cases. if you cant get the same size rad again you can use extensions to make up the space.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jan 24, 2007 9:20 pm    Post Subject:
As well as swapping the rad, bear in mind that all the others are probably equally rusty (being equally old and filled with the same water).
Probably you have no corrosion inhibitor in your system icon_sad.gif and it is full of corrosion sediment.
It will be a good idea to replace the rusty rads, do a chemical clean and refill with inhibitor. If none of the others are leaking yet it will be more convenient to replaace them during the summer. Modern radiators usually have fins on the back and give out slightly more heat so a slightly shorter one will be OK, or you can fit doubles (which is reasonably easy if the pipes come through a wooden floor so will move a bit) which give out considerably more heat.
If you can afford an extra £100 or so for a Magnaclean or similar it will attract and retain circulating black sediment and prevent it from causing (more) blockages and damaging your pump and boiler.
Back to top
 Alert Moderators
diane1
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 25, 2007 8:25 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
replacing rusty radiator 3 880 Fri Aug 03, 2007 7:46 am
rusty airvent on my radiator 6 380 Wed Sep 24, 2008 4:31 pm
Rusty Bathroom Ladder/Towel radiator 2 420 Sat Nov 08, 2008 9:31 am
rusty 3 way valve 31 620 Tue Apr 21, 2009 7:21 pm
Immersion heater cylinder has rusty bolt at bottom 5 120 Sun Jul 19, 2009 5:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
