We've had this one before from another post. Plastic internal by-pass shuttle needs replacing, common for this model. Only make sure you get a proper service agent (try if manufacturer can reccommend) or you may end up with some burke who thinks it's another printed circuit board fault.
Vokera do a cheap service kit with all the perishable hydraulic bits and pieces including the bobbin/washer making your screaming nose. Get someone to fit the whole kit in about an hour...
