Transformer for electro magnetic door lock?
[breezer idealy wonders] 24volt.................hmmmmmmmmm
access control is usualy 12v, fire alarms are 24v
Not one of those thingies that keeps the door open, connected up so it de-energizes when the fire alarm sounds allowing the door to close?
and you're using it for what? AFAICT, that wont hold much force. :oops:
The long bar type breezer showed a pic of will take the weight of a person and much more. (I've tested them ;) :LOL: ) In fact the weakest point of those magnets are the fixings holding them to the door/frame.
Ideally to prevent access to an under stairs cupboard where there is an alarm control panel connected to a phone line...... but I'm guessing now that it's as good as useless ! Really I didn't want a door lock as it will look unsightly, but it might have to be that!
oh, one of them!
best use for that is a paper weight
it has bits missing
as you see from the above you have no way of fixing it, and you have no "wobble plate" also those ones would be of no uses since you would have to fix it outside of the door, and as crafty says they can not hold much.
bin it
that's one for ebay then! I'll be fitting a lock to that door instead - much more fool proof, thanks for the info though, it's been an interesting post !! :LOL:
coopersim, access by who?
why not fit a "mortice lock"
i have one on my shed, you can get ones that are designed to fit on the edge and not actulay in the timber (sorry dont know what they are properly called)
mine cost about 15
that way you only have the keyhole outside
That was my other option, a euro lock style mortice, that is what I will do !
..... does anyone want a magentic fire door holder......? :D
breezer said:
... ones that are designed to fit on the edge and not actulay in the timber (sorry dont know what they are properly called)
"Rimlock"
Most of them are made by Avocet and sold under own-brands.
Funnily enough you can often buy a bolt-on Safe Lock for the same money
breezer said:
so its a white box with a red cross, not seen that one before
Funny...but not fair :LOL:
Even ninebob has 1 in his post..Hope its not infectious :LOL:
