Joined: 29 Jan 2007 Posts: 4 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Mon Jan 29, 2007 11:25 pm Post Subject:
insulating the roof
i am in the process of considering laying boards on the joists to create storage space. after reading all the previous suggestions i am considering running 3" x 1" timber at right angles across the existing joists for strength and to allow air flow and to keep the wires away from the insulation. what my main problem is that i have just roof tiles and nothing else. i believe i need to leave a 50mm gap between the tiles and the insulation for airflow. so what do i put between the rafters?? what goes up first?? what do you all recommend??
i have heard mention of waterproof membrane or something!?!? thanks all!!
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Tue Jan 30, 2007 11:01 am Post Subject:
A lot depends what you want to do in the loft, the flooring idea is okay but I would leave the roof rafters insulation alone as you may increase condensation problem depending what you wan to do up there, is it just for storage?
__________________ Always judge a man by the way he treats someone who is of no use to him
Posted: Tue Jan 30, 2007 1:48 pm Post Subject:
HI THANKS FOR REPLY. GONNA USE IT FOR OCCASIONAL USE AS A SPARE ROOM FOR AN OFFICE. JUST A COMPUTER TABLE, CHAIR AND A FEW BOXES OF STORAGE. WILL BE IN THERE FOR A COUPLE OF HOURS EACH DAY SO IT NEEDS TO BE FREE FROM DUST AND WIND, A PROBLEM THAT I HAVE GOT AT THE MOMENT. BEFORE IT WAS EMPTIED OUT ALL THE ITEMS IN THERE WERE COVERED IN DIRTY FILTHY 'DUST' FROM OUTSIDE THROUGH THE TILES. HOPE SOME ONE CAN HELP!!??
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Tue Jan 30, 2007 3:00 pm Post Subject:
An unfelted roof will always be filthy. One day perhaps you will have it re-roofed and can fix that.
You might think about making a sort of "box" as a room to sit in while you are up there hiding from your wife.
You can get a reflective bubble film that you can staple to the rafters, it is supposed to provide thermal insulation and would also keep the dirt out, but I haven't used it.
Posted: Tue Jan 30, 2007 10:14 pm Post Subject:
thanks for that link!!
daft question here!!
will i need to first put up the underlay followed by insulation (looks like giant rolls of thick foil) or can i just use the 'foil' insulation stuff. will this 'foil' stuff keep out the moisture or is that the job of the underlay?
could i just use the underlay or will this not help with insulation?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
