briggs
Joined: 30 Jan 2007 Posts: 1 Location: Essex, United Kingdom Thanked: 0 times
Posted: Tue Jan 30, 2007 8:57 am Post Subject: towel rad cold at top |
Here\\\'s the problem.
Towel radiator upstairs slowly seems to be getting cold at the top (approx 1 \\\"rung\\\" every 2 days). There doesn\\\'t appear to be any drop in pressure on our combi. I\\\'ve bled the towel radiator a couple of times but the cold area at the top keeps returning. Any ideas? Am I likely to have a small leak somewhere or is there anything else I can look at?  |
ChrisR
Joined: 24 Jul 2003 Posts: 18662 Location: London, United Kingdom Thanked: 62 times
Posted: Tue Jan 30, 2007 9:59 am Post Subject: |
Try putting corrosion inhibitor in the system. |
patagonia
Joined: 30 Mar 2007 Posts: 126 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Fri Mar 30, 2007 4:34 pm Post Subject: Towel rad cold at top |
Briggs - Did you try this and did it work? |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Fri Mar 30, 2007 5:06 pm Post Subject: |
After bleeding the towel rail, did you top up pressure each time? __________________ Dave
DRL Gas Services |
