Installing a DE Dietric induction hob
30 Jan 2007
I have just bought a DE Dietric induction hob, the cable on the hob has two neutral cables pinned together and two live wires pinned together and states fuse 32/16 amp. It mentions about splitting the L1 L2 but also shows a diagram connecting them as they are.
I assume this can't just be wired to a plug and pluged in, can I wire it up to the same single 30Amp point as the oven?
You're right it can't be plugged in, it needs to wired into the cooker connection unit.
The rating for the cct MCB should be 32A.
Ok, thought so. So can i double up the connection for the hob and the connection for the oven which is one socket behind the oven. I think the cooker fuse is 30amp
You will need to change the fuse for a 32A MCB (You can get a replacement plug-in type).
As regards connecting the hob into a skt, if it is stating 16A then no. A skt is fused at 13A.
Why change 30 for 32? Just to give you an extra 460W capacity?
We don't even know the rating of this appliance or the circuit details (like what size cable it is wired in, what length etc...)
OP, please provide this information before we can offer full advice.
