plumbgirl
Joined: 30 Jan 2007 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Tue Jan 30, 2007 6:54 pm Post Subject: removing an OLD radiator |
Just moved to the UK from the US and need advice. Moved into an old terraced house with old cast iron radiators on the walls, but not the original ones I'm told...want to remove all of them to repaint/plaster house and repaint radiators. My question is this: Is removing an old radiator the same task as removing a newer model? For example, my radiators are fitted to the floor and not mounted on brackets to the wall. Also, the two plastic-capped bits are not both located at the bottom of the radiator, one is at the top. Have not found much help online so far. Any advice welcome, cheers! |
kevplumb
Joined: 18 May 2004 Posts: 19145 Location: Tennessee, United States of America Thanked: 400 times
Posted: Tue Jan 30, 2007 6:58 pm Post Subject: |
yes just the same
turn off both valves undo bottom one drain rad undo other one and bobs yer mothers wotsit  __________________ a little thanks
goes a long way |
plumbgirl
Posted: Tue Jan 30, 2007 8:31 pm Post Subject: |
Thanks, Kevplumb. I'll give it a shot! |
