DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Alpha 240P
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
chrisGE
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 30, 2007 7:14 pm    Post Subject:
Alpha 240P
Reply with quote Thanks
Boiler fires up for 20-30secs then switches off and then fires up again. It does this continually.On/off on/off all the time. This happens with both hot water and central heating. Any ideas on what is causing this would be appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
spen
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 04, 2007 9:25 pm    Post Subject:
i had this problem a while back and it turned out to be the temperature sensor located just inside the boiler,in a pipe,there are two i think one for the hot water and one for the central heating,i'm not a plumber but remember the engineer telling me about it,it used to happen even if the tap wasn't open!
Back to top
 Alert Moderators
micky p
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 04, 2007 9:46 pm    Post Subject:
yeah sounds like it could be NTC thermistor. also could be worth checking the fan assembley and aps. I have had a few that got clogged up with dirt and needed cleaning out causing the aps to not make/work. Also ive had a few where the silicone tubing from fan to aps had gone hard and brittle causing the same problem.
Back to top
 Alert Moderators
ACOperson
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 04, 2007 9:58 pm    Post Subject:
Fan venturi
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Feb 05, 2007 8:58 am    Post Subject:
Pump.
next??!!
Back to top
 Alert Moderators
micky p
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 05, 2007 8:11 pm    Post Subject:
ACOperson wrote:
Fan venturi
this is what i meant. seems to be a common problem especially when the ones like i had been looking at, that have not been serviced for approx 8 years. seemed to be a realiable boiler upto now but to be expected really.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Feb 05, 2007 9:41 pm    Post Subject:
How long does it stay off before it has another go at lighting? Couple of seconds? Half an hour??
Back to top
 Alert Moderators
micky p
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 8:12 am    Post Subject:
does the orange light on the front with a picture of a chimmney and a fan on it light up when there is a demand. Then once the light is lit up it should go out and the boiler should light. If this light remains lit then it is more than likely the APS or Fan venturi.
Back to top
 Alert Moderators
empty_vessel
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 30, 2007 3:22 pm    Post Subject:
Alpha 240P
My Alpha 240P has exactly the same snag, it lights and heats either DHW or CH but then the fan orange light goes on for approx 30 sec (when fan light goes on boiler stops heating) once fan light goes out the boiler starts to heat again. This happens again and again until I stop attempting to have a shower/get hot water for a bath.
I have some visible signs of a v slow leak around the DHW temp sensor and the flue is not sealed all that well, not to mention it's a bit mucky inside and the DHW flow switch is slow to get the boiler going (that's probably a separate fault).
The plumber recommended to us is taking a while to ring back (busy time of year me thinks!), any quick ideas to help me have a shower that stays hot for more than 30 secs?
Ps Can anyone recommend any good plumbers without too long a waiting list in the Dorchester area?
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 17 times
PostPosted: Thu Dec 13, 2007 9:52 pm    Post Subject:
Just get a good Alpha engineer.
Orange light is often a sign it needs a good clean up top, DHW thermistor leak is a 5 minute fix, slow DHW startup could be just a diaphragm (10 min job).
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Alpha 240P Hot Water Problems 10 720 Mon May 07, 2007 9:55 am
Alpha 240P Pilot Light 2 340 Mon May 07, 2007 11:51 am
Alpha 240P Pilot Light 10 660 Thu Apr 05, 2007 11:11 pm
Ocean Alpha 240P Boiler 2 960 Tue Apr 03, 2007 5:23 pm
Alpha 240p Boiler HW and CH issues 2 120 Tue Dec 30, 2008 10:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
