DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal Classic RS250 boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
dmb06851
from United Kingdom
PostPosted: Tue Jan 30, 2007 8:03 pm Reply with quote
We have recently moved house.
When the thermostat in this boiler opens it kicks up a hell of a racket on radio and telephone (wired, not cordless.) If there is a suppressor fitted then it has obviously failed.
Ideal's web site has installation instructions for a more recent boiler so the construction is a bit different.
I would like to know the sequence of disassembly to the point where the connections on the thermostat are accessible so I can fit a new suppressor.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3490 times
PostPosted: Tue Jan 30, 2007 10:29 pm Reply with quote
Boiler thermostats dont normally have an RF supressor. ( Ya Ya ! Yes we all know the Baxi BBU does and some Ideals have a line supression filter ).
You can always fit one yourself if its your boiler!
These thermostats rely on a bistable moving contact to give a rapid snap action. If its not snappy like a crocodile then it should be renewed.
Of course it sounds as if your radio may not have a very efficient antenna! Are you still listening on MF or LF by any chance? If so better change to VHF FM and take advantage of the relative immunity of the discriminator, pulse counting or phase locked loop demodulator to amplitude interference.
Tony Glazier
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jan 30, 2007 10:33 pm Reply with quote
Back to top
 Alert Moderators
dmb06851
from United Kingdom
PostPosted: Tue Jan 30, 2007 10:35 pm Reply with quote
Thank you Tony.
Did you overlook that I mentioned there is inteference on the (corded) 'phone too?
An f.m. discriminator's immunity to amplitude variations is only realised when the receiver is fully, or nearly, quieted, i.e. when the discriminator is limiting.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jan 30, 2007 10:41 pm Reply with quote
when you say the stat kicks in and causes interferance can you explain in laymans terms? for no other reason than to educate me.
Back to top
 Alert Moderators
dmb06851
from United Kingdom
PostPosted: Tue Jan 30, 2007 10:43 pm Reply with quote
I'm a retired electronics engineer.
www.davidbridgen.com
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Tue Jan 30, 2007 11:03 pm Reply with quote
its arcing cos the suppressor (capacitor) aint working
Back to top
 Alert Moderators
dmb06851
from United Kingdom
PostPosted: Tue Jan 30, 2007 11:31 pm Reply with quote
Sorry bster, I overlooked your question.
When a switch carrying current to an inductive load (in this case the gas valve's solenoid) opens arcing takes place across the opening contacts.
This is a spark transmitter, similar to, but rather smaller than, that used by Marconi etc etc etc.
A spark transmitter has a very broad bandwidth, i.e. it radiates energy on a very wide range of frequencies.
The wiring to the contacts, as far as this arcing is concerned, is an antenna which radiates the damned interference!
Connecting a suppressor, which usually is a small value capacitor in series with a small value resistor, across the contacts reduces the size of the arc and therefore the signal strength of the transmission.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Tue Jan 30, 2007 11:33 pm Reply with quote
If memory serves me right for the old RS boilers .Drop the front cover.. on the underside of the boiler at the front just behind where the front cover top touches on each side is a little posi drive screw undo these and wiggle the bottom section of boiler off.. Your thermostat is held in a metal casing which is held in place with one screw into the underside of the main boiler casing undo this and it should allow you acces to stat.. You will not break any case seals doing this so no worries there. Can`t remember if this boiler was ever fitted with a suppresor though
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jan 30, 2007 11:39 pm Reply with quote
dmb06851
cheers - more understandable than that other language you and the 'Adge' were speaking in the beginning icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ideal Classic RS250 gurgling noises, sludge in tank, pics 27 3740 Wed Dec 01, 2010 5:11 pm
ideal classic RS250 kettling 55 1600 Wed Oct 22, 2014 11:31 pm
Ideal Classic (LXRS & RS RS250?) 3 600 Mon Dec 10, 2007 9:18 pm
Ideal Classic RS250 Problems 5 120 Mon Feb 09, 2015 4:38 pm
Ideal Classic Boiler - Airing Cupboard Pump Won't Stop 11 680 Sun Nov 07, 2010 2:07 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
