ch problems
17 Mar 2004
Hi everyone, after some much needed advice.
I have recently had a glow-worm 24Ci system fitted into my bungalow. It worked perfect until the plumber fitted a radiator into the bathroom, since then when I turn the hot water on the boiler makes a god awful bang then over heats, it has got progressively worse and now the boiler constantly trips out when I turn it on.
The system has a 22mm feed pipe reduced to 15mm where 4 rads are fed, the return is also 15mm then upto 22mm, 4 of the 6 rads are 10mm microbore, 2 are 15mm flow and return. Any ideas--please.
I have called the plumber but he now is in Amsterdam with a 'big' project_hmm !!
Jim.
