Use aqualpanel, is this for a shower over the bath or in a shower cubicle, should really be tanked though, do a search on here, plenty of info there, if not get back to us
Took out scabby old shower in recess. Originally had formica panelling. When took these off, found 1 side was sheeted in hardboard, 1 side in plasterboard, and 1 in ply!!
Water will eventfully seep through the grout, then the tiles will start to fall off, I've seen loads of them with this problem, the plasterboards goes all black, mouldy & damp
