delboy630
Joined: 01 Feb 2007 Posts: 2 Location: Aberdeen, United Kingdom Thanked: 0 times
Posted: Thu Feb 01, 2007 10:44 pm Post Subject: Leaking Wingnuts |
Installed a closed coupled toilet. But the wingnuts that attach the cistern to the basin keep leaking. Is there any thing i can do to stop it?
Thx delboy |
kevplumb
Joined: 18 May 2004 Posts: 19144 Location: Tennessee, United States of America Thanked: 400 times
Posted: Thu Feb 01, 2007 11:01 pm Post Subject: |
they are not leaking either the donoght between the cistern and pan is
or if the bolts go through the cistern base they are  __________________ a little thanks
goes a long way |
Blasphemous
Joined: 02 Oct 2006 Posts: 3501 Location: United Kingdom Thanked: 20 times
delboy630
Posted: Fri Feb 02, 2007 12:32 am Post Subject: |
The wingnuts are the ones that connect the metal plate on the basin. They do not enter the actual cistern. Hope this helps?
delboy |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Fri Feb 02, 2007 1:59 am Post Subject: |
Its pretty obvious to any DIYer that the stud comes from somewhere!
The top of the stud is a bolt INSIDE the cistern. This has a flat metal washer and a thick rubber washer on the inside and a plain nut and a metal washer on the outside ( usually ).
The threads extend downwards by about 50 mm to form the studs on which the wing nuts are screwed to squash the doughnut and hold the cistern onto the pan.
Need to edit to add that there are also some, usually older ones, where the stud does not go into the cistern and just starts at the top of the metal plate. In that case if the donought is properly squashed and the cistern correctly located then there is no scope for it to leak.
There were some thick flat foam plastic/rubber washers to do the job of a doughnut. They never sealed properly and should be replaced with the correct doughnot type.
Tony
gigz
Joined: 07 Oct 2006 Posts: 590 Location: United Kingdom Thanked: 4 times
Posted: Fri Feb 02, 2007 6:26 am Post Subject: |
Take the cistern off the pan and check the dohnut washer is seated correctly, if it is and still leaking buy another one. These also sometimes leak if the gap behind the cistern is a bit wide and is forcibly screwed back to the wall. |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Fri Feb 02, 2007 6:48 am Post Subject: |
It's annoyingly common to find that if you put the cistern on the pan and do it all up, the cistern leans forwards by 3cm. If you create a wedge shaped donut to tilt it back it will seal but you see a gap at the front between p & c. |
