NigelVockings
Joined: 02 Feb 2007 Posts: 1 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Fri Feb 02, 2007 8:57 pm Post Subject: Leaking Pipework |
I have had a new combi-boiler fitted to an existing pipework / radiator system. Obviously the new system operates at higher pressure than the original system. The system loses pressure over a couple of days and cuts the system out. I have had the boiler checked and it is not leaking internally and there are no obvious signs of leakage. It woudl appear that there is a leak from the pipes under the floor. Unfortunately the pipes are set into the concrete floor. As the system is in my Grandmothers house I am reluctant to put her through the disruption of fitting all new pipes. Does anyone know of a solution to detect / mend a leak underfloor, or have any ideas on other options ? Best Regards Nigel |
bster
Joined: 29 Jun 2006 Posts: 941 Location: United Kingdom Thanked: 0 times
Posted: Fri Feb 02, 2007 10:04 pm Post Subject: |
This is no help whatsoever but the company that i work for will not install a pressurised CH circuit on a system with pipes in a concrete floor (due to the problem that you may now have), they insist on new 'drops' to downstairs rads etc.
You may have to dig the floor up or have new drops - but hopefully there is another reason for the pressure drop (fingers crossed). __________________ I am newly qualified, so don't rely on my advice get a second opinion!!! |
ollski
Joined: 08 Oct 2003 Posts: 4493 Location: Birmingham, United Kingdom Thanked: 10 times
bster
Posted: Fri Feb 02, 2007 10:17 pm Post Subject: |
have you checked to see if the pipes are run in ducting within the floor? __________________ I am newly qualified, so don't rely on my advice get a second opinion!!! |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
gavinda
Joined: 20 May 2006 Posts: 1018 Location: Berkshire, United Kingdom Thanked: 1 time
Posted: Sat Feb 03, 2007 11:39 am Post Subject: |
i reckon leak sealer for now may work..ive use it many a time for those 'invisible' leaks but to be honest i'd start budgeting fo the new drops to be done. you obviously cant tell wether the pipes have been lagged in the floor and once one starts to go..its a slippery slope |
