3 Gang switch correct wiring
4 Feb 2007
Dorset
Can someone confirm that this is the correct way to wire this 3 gang switch? all switches are one way.
well it will work, and yes its safe, but looks a bit messy
breezer Thanks
Is the circuit messy or the way i will be wiring it messy ?
Is there any easier or better way of doing this?
just the way you are wiring it.
whats it for?
although the neutrals are drawn connected you will have t physicaly connect them.
usualy this is done in the ceiling rose, which is why i asked whats it for
3 separate light circuits using the new colour wiring BROWN & BLUE & EARTH
The neutrals in the previous switch were all connected in a terminal block & not connected to the switch
So your saying a neutral will need to be connected to the switch ? if this is correct then where do I connect this
With the Neutrals connected with a terminal block
_______________________________________
Lynda, moderator
please note forum rules> general information, item g
i never said the neutrals need to be connected to the switch did i?
Breezer, No you didn't I was just checking to see, if I had interpreted what you had said, correctly.
I do appreciate your advise.
Your proposals are fine.
It is becomming quite common to wire lighting circuits like this, with the feed taken to the switch.
Wired & working fine, thanks to both breezer & RF Lighting for their comments & advise
