DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric socket under water pipes
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
fjb123
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 05, 2007 12:47 pm    Post Subject:
Reply with quote Thanks
When our new washing machine was delivered at the weekend, the delivery people refused to install it because the electric socket to plug the machine in was under two water pipes, which ran left to right above it.
If we move the socket from the back wall to the side wall, the washing machine won't fit in the gap. If we move the socket above the unit, the electrician will need to cut our work surface, take off our tiles and go through our unit.
There has been a washing machine in that gap for years - can we go ahead and install it there, even though the pipes run above the socket??
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Feb 05, 2007 1:13 pm    Post Subject:
I'd say that the delivery people are being paranoid, but is it merely pipes that are above the socket, or coupling/fittings/valves too?
Suggestions:
1. Ensure that the washing machine circuit is protected by an RCD at the consumer unit.
2. Tack a piece of DPM behind the pipes, trailing down over and in front of the socket, such that the water from a leak would be directed away from the electrics and straight onto the floor.
Back to top
 Alert Moderators
fjb123
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 05, 2007 1:51 pm    Post Subject:
I must admit that I do not have a trained eye, but from what I can see, they just look like plain pipes! There are certainly no taps or valves or anything. The delivery people pointed to a bit of oxidation on the copper pipe which was about 10cm to the right of the socket, and said that was evidence of previous leaks, and were saying that it would make our buildings insurance invalid, etc, etc.
And then went on to say that it might be easiest if they just delivered it and we got someone else to install it... It was a Sunday after all!
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Feb 05, 2007 1:57 pm    Post Subject:
Re: Electric socket under water pipes
What knowledgable delivery people they were! Not only do they know about plumbing, and electrics, but also buildings insurance. Verily they must be the best-trained delivery people in the whole Kingdom. icon_eek.gif
Back to top
 Alert Moderators
fjb123
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 05, 2007 5:16 pm    Post Subject:
Heh heh. Quite so! I was truly blessed.
Thank you for taking the time to give me your thoughts on this though.
Back to top
 Alert Moderators
stevesey
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 5:59 pm    Post Subject:
Sounds like they are especially knowledgable about excuses that enable them to avoid the install and knock off early.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
phono socket wiring 2 500 Sun Apr 29, 2007 11:49 am
Gas pipes and electric oven??? 2 320 Mon Feb 25, 2008 3:04 pm
OVERFLOWING WASTE PIPES 2 560 Sun Aug 27, 2006 12:22 pm
How do you turn off your machine pipes! 28 800 Sun Feb 10, 2008 10:47 pm
How do i take of the metal rings at the top of the pipes? 3 420 Wed Nov 02, 2005 7:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
