Peter_Claringbold
Joined: 05 Feb 2007 Posts: 2 Location: Northamptonshire, United Kingdom Thanked: 0 times
Posted: Mon Feb 05, 2007 2:39 pm Post Subject: 2 Gang, 2 Way Switch. |
I had 2 separate switches in the main bedroom in my house, one was a 1 Gang, 2 Way Switch and powered the landing light, along with 2 other switches (located upstairs & downstairs) & the other was a 1 Gang, 1 Way Switch powering the main bedroom. I've now brought a metal 2 Gang, 2 Way switch & have got to get it to power both the main bedroom & the landing, along with the other two switches. The new metal 2 Gang, 2 Way switch has got com, 1 way, 2 way & com, 1 way, 2 way. I have 2 red, 2 blue & 2 green wires for the landing & a red, black & green for the bedroom. The bedroom light is fine, but I can only get all 3 light switches to work for the landing occasionally (when the main bedroom switch is on), which means I've wired it up wrong. Any ideas?
Your help would be much appreciated.
Regards,
Peter. |
ricicle
Joined: 14 Sep 2006 Posts: 3485 Location: Gloucestershire, United Kingdom Thanked: 19 times
Posted: Mon Feb 05, 2007 2:54 pm Post Subject: |
Did you check the old switch? Was it a grid switch (seperate parts)?
For a light to work 3 way it needs 1 intermediate switch and it sounds like your landing light switch in the bedroom might have been this.Did the old switch for the landing have 4 terminals in it?If this is the case then I'm afraid the 3 way switching will not work as you have a 2 way switch!!
If you are not sure is there any chance you could post a picture? __________________ Empty barrels make the most noise. |
Peter_Claringbold
Posted: Mon Feb 05, 2007 3:02 pm Post Subject: |
I did check the old switch and it did indeed have 4 terminals, I feared this might be the case, but I've kitted out the whole house in one particlur style of light switch & B&Q do not supply a 4 terminal light switch in that range.
Is there any way around it?
Many thanks for your time anyway, much appreciated. |
ricicle
Posted: Mon Feb 05, 2007 4:25 pm Post Subject: |
If that is the case with the availibility of an intermediate switch in that range then you will have to do away with the switch for the landing.You can join the 4 wires for the landing together in the back of the switch box in connectors(or crimps if space is tight) Join red to red and blue to blue.
You can then just fit a standard 1 gang 1 way for the bedroom __________________ Empty barrels make the most noise. |
