DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Standing Water in Drain
This topic originated from the How to page called Clearing blocked drains
Click here to return to the page called Clearing blocked drains.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
rvgledhill
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 5:03 pm    Post Subject:
Reply with quote Thanks
The drain which takes away the roof rainwater, kitchen sink and bath wastewater was recently blocked causing water overflow and also seep into cellar.
Now unblocked I still have standing water in the drain about a foot below the grid. It doesnt appear to get any higher and the cellar is not flooding.
About 3 foot below the grid the drain bends and goes off to the sewer (I presume).
Is this standing water normal or is there still a blockage problem with my drain ?
Thanks in advance,
Rob
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
RayJ
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 5:05 pm    Post Subject:
No, its normal.Its the water laying in the 'u' bend forming a trap to prevent smells coming up through it.
Back to top
 Alert Moderators
rvgledhill
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 5:40 pm    Post Subject:
Many Thanks for your response.
Rob
Back to top
 Alert Moderators
straygoat
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 05, 2009 1:47 pm    Post Subject:
Hey Ray,
I have a similar setup, only I've got a problem - the 'trap' water gets stagnant over night (or anytime when there's no water being used for a few hours) and starts to stink. Always a problem in the summer as the drain is in our lean-to which gets hot. Have you got any advice about how to stop it smelling? I've tried bleach etc. but it doesn't stop the problem. Is there any way to clear the drain so there's no water in the trap so that I can clean it out properly?
I saw someone else mention that they pulled out the 'trap' in the u-bend, cleaned it then put it back and the same problem went away. I can only just get my fingers in the out pipe (because I can't reach, not because it is blocked) and can't feel anything there - how far in would this mysterious trap be?
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Wed Aug 05, 2009 2:19 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Standing water in soil stack 20 780 Tue Feb 26, 2008 11:38 pm
standing water on shower sealant 10 660 Wed Jan 16, 2008 12:49 pm
Hot water tank insulation - standing heat loss. 3 900 Wed Apr 09, 2008 3:20 pm
Standing water / waste in solvent welded pipes - bad? 3 540 Wed Mar 14, 2007 10:13 pm
Floor Standing Heat Only Boiler 9 240 Wed Feb 04, 2009 1:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
