DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
2 LIGHTS 2 SWITCHS IN 1 BOX
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
andy d
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 6:59 pm    Post Subject:
Reply with quote Thanks
I WANT TO WIRE MY OUTSIDE LIGHTS AND MY CONSERVETORY LIGHTS INTO 1 DOUBLE SWITCH, I HAVE 2 REDS, 2 BLACKS, AND 2 EARTH\\\'S. I KNOW THAT THE EARTH\\\'S GO TO THE BACK BOX BUT WHERE DO THE OTHER WIRE\\\'S GO AND DO I NEED A LOOP WIRE icon_confused.gif
__________________________________
lynda, moderator
please note forum rule 6
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Tue Feb 06, 2007 7:56 pm    Post Subject:
Hang on. Are the outside lights new? And you've just run a single cable from them back to this switch? If so it wont work.
Why did you SHOUT your entire message? We can hear you if you talk like this.
Go away and come back armed with some more detail.
Out of interest, if the 2 cables you have there are just switch drops, and carry live (red) and switched live (black), the way to wire them is
RED to COM
BLACK to L1
However I suspect that is not the case, as i said above . . . .
tell us more.
Back to top
 Alert Moderators
andy d
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 08, 2007 12:05 pm    Post Subject:
Hi There
My outside lights are a couple of years old and they go into a junction box and then down into my light switch. My new conservatory lights go straight to the switch and this is where i am having the problem of getting the wires the right way round as i said before i have 2 red, 2 black and 2 earth. i have tried putting both reds and both blacks together into a single switch but all i end up with is one set of lights on permanetly no matter which position the switch is in. Please help as it is driving me mad on what to do. icon_confused.gif
Back to top
 Alert Moderators
stem
from United Kingdom
Thanked: 18 times
PostPosted: Thu Feb 08, 2007 12:45 pm    Post Subject:
Is this what you have done? If so as crafty says it won't work. (we know now it's the conservatory lights that are new)
Light switches only switch the live conductor. Usually there will be no neutral at the switch, that connection is made at the junction box. If you have just run a cable from your new conservatory lights to the switch, It will never work as you will need a neutral connection.
Please confirm what the situation is and someone will be able to help you.
Back to top
 Alert Moderators
ELZ4742
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 08, 2007 1:23 pm    Post Subject:
if the chaps put the reds and blacks in the switch and it works theres no neurtal at the switch but if it works there must be a nuetral at the fitting.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Thu Feb 08, 2007 4:59 pm    Post Subject:
yeah you have no neutral at the switch, you cant supply a new light from there.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Looking for switchs 2 300 Tue Jan 20, 2004 12:05 pm
Earth and Lights? 5 160 Sat Feb 02, 2008 6:03 pm
Pelmet lights req socket but on lighting circuit. 4 1080 Tue Jan 29, 2008 6:11 pm
wiring for led lights in path panels (roper rhodes porto) 3 1160 Sun Jan 27, 2008 12:17 pm
External Deck lights 2 240 Sun Feb 03, 2008 3:38 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
