DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
shower cable size
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
  View previous topic :: View next topic
Author Message
breca
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 07, 2007 2:05 pm    Post Subject:
shower cable size
Reply with quote Thanks
If i fit a 8.5kw shower with a 10 metre run to consumer unit would a 6mm cable be ok or would i nedd a 10mm cable.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 07, 2007 2:11 pm    Post Subject:
6mm^2 twin and earth will be sufficient for a 37A load providing it isn't subject to other derating factors (high ambient temperatures, running through insulation in walls/lofts, grouping factors etc.)
Let us know how you intend to install the cable and then we can verify if 6mm^2 will be ok. It might be worth using 10mm^2 cable regardless though so if you decide to upgrade the shower in the future you don't need to rip out the old.
Davy
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Wed Feb 07, 2007 2:15 pm    Post Subject:
6mm˛ will be fine on a 40Amp mcb as long as the cable doesn't follow a route through thermal insulation and is not grouped with other cables
Are you aware that this work is notifiable to your local building control under Part P of the building regs?
Most manufacturers recommend the use of a 30mA RCD to protect the circuit also and I second this as will the majority of sparks on here.
Is your local supplementary bonding up to scratch?
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
sm1thson
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 07, 2007 2:53 pm    Post Subject:
10mm will mean you dont have to do it again when you put a more powerfull shower in.
Back to top
 Alert Moderators
breca
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 07, 2007 3:39 pm    Post Subject:
Thanks for your help,what is a supplementary bonding?and why do i have to notify building control.
I shall only be laying the cables during the building stage of an en-suite,i sghall get a competant electrician to do the clever bits at the end with rcd,etc.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 07, 2007 5:27 pm    Post Subject:
In that case don't worry about supplementary bonding and don't worry about building control - your electrician will sort all that for you.
You are very close to the limit of 6mm^2 cable. If I were you I'd put in 10mm^2 just for future proofing.
Davy
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Wed Feb 07, 2007 5:53 pm    Post Subject:
Davy
So make sure he is registered and able to certify his work regarding Part P icon_wink.gif
__________________
Back to top
 Alert Moderators
martynduerden
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 09, 2007 1:11 am    Post Subject:
All this Part p nonsense thank god i don't do houses ! although i do get worried by the occasional diy-er asking how to rewire a house!!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
10.8 kw shower cable size 12 1360 Sun Apr 20, 2008 9:38 pm
9kw shower.....what size cable?? 4 1440 Thu Jul 03, 2008 3:01 pm
cable size and mcb for shower install 2 1240 Thu Mar 27, 2008 8:57 pm
Shower size for 6mm cable? 15 1840 Thu Mar 20, 2008 8:11 pm
Identifying electric shower cable size [with pic] 12 4120 Sun Feb 10, 2008 8:33 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
