Removed tiles and part of plaster!!
5 Feb 2007
Cheshire
I've removed the tiles in my bathroom to re-tile. In parts the plaster has come of as well but only patchy the remaining plaster is solid. I'll try and explain better, bits of pinky plaster has come off, the remaining pinky stuff is solid but behind where it has come off the walls are grey, no wood or board. What do I need to do to re-tile. Any help appreciated.
Many thanks in anticipation
Kath
1. Be thankful that the loose plaster is coming away now, rather than after you've re-tiled!
2. Tap the remaining plaster skim coat to detect any more loose patches - when you find them then hack them off. Anything that's firmly attached will be difficult to remove.
Here's an example of excellent tool for scraping off loose plaster:
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=102100&ts=14424&id=45940#
3. When you've removed all loose plaster, use a stiff brush to remove dust and other loose crud.
4. Paint the wall with a purpose made tile adhesive primer, e.g. Bal Prime APD.
Never heard of the stuff, but shall go and get some. Do I just tile over it???
When I take my tiles off the other wall I am expecting to find the same scenario but that's going to be on an internal wall, what will I have to do there?
Many thanks
Kath
