mira 9kw shower
11 Feb 2007
Edinburgh
low flow warning light on.water is fed direct from mains no water flow.i have cleaned the inline filter.turned all dials to low also tried sucking the hose still no water.cheers derek.
Slugbabydotcom said:
Could be a sticking solenoid valve. If its getting its voltage is it opening?
Is there water getting in to the shower?
thank you for your advice i will check it out.
cheers derek
