grenadier
Joined: 11 Feb 2007 Posts: 3 Location: Sheffield, United Kingdom Thanked: 0 times
Posted: Sun Feb 11, 2007 6:32 pm Post Subject: weird circuit |
This morning a wall light almost came off the wall, I fixed it back on putting the wires back in place. Switched the light on and the fuse box clicked. Switched off the fuses again, checked the wires in the wall light and tried again, this time they cam on. So i had to remount it all, left it all day. And now they wont come on, I've had them on and off the wall all day but they still wont work. I have left them off the wall now.
But, the main light in the living room, is now very dim when on and it also turns the kitchen spot lights on (which are also dim). If i flick the kitchen spotlight switch, they come on bright, but 2 of them switch off!
If i turn the main light in the kitchen on, it does not come on, but the spotlights do, and they are dim again.
Is it possible that a fuse has gone in my main box? |
CJT
Joined: 08 Feb 2007 Posts: 2 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Sun Feb 11, 2007 6:34 pm Post Subject: wall lights |
how many wires were at the wall lights and what colours did you have |
dingbat
Joined: 29 Sep 2003 Posts: 2205 Location: West Midlands, United Kingdom Thanked: 0 times
grenadier
Posted: Sun Feb 11, 2007 6:35 pm Post Subject: |
there was a red, black and earth. |
grenadier
jj4091
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Mon Feb 12, 2007 8:20 am Post Subject: |
If the left screw head on the bracket in your first pic is cutting into the cable, as it appears to be then I would think you have a short to earth which will probably be your problem. If it is, then rectifying it will be difficult without doing a bit of damage to the plasterwork. |
bernardgreen
Joined: 03 Nov 2006 Posts: 3609 Location: Bedfordshire, United Kingdom Thanked: 22 times
Posted: Mon Feb 12, 2007 8:23 am Post Subject: |
I wonder if the two "unused" wires are part of the other circuits. like a looped neutral may be.
Dim lights are always a worry....... |
tim west
Joined: 27 Nov 2006 Posts: 10443 Location: United Kingdom Thanked: 15 times
Posted: Mon Feb 12, 2007 1:48 pm Post Subject: |
my advice to you is call a qualified electrician in NOW! |
Lectrician
Joined: 18 Jul 2004 Posts: 5166 Location: Devon, United Kingdom Thanked: 20 times
Posted: Mon Feb 12, 2007 3:19 pm Post Subject: |
Odd switching like that can occur when you have a live/earth fault and a high resistance earth. |
