Hi all - I'm hoping someone with superior knowledge to me can help...
I have a gas fired open vented system with an expansion/header tank in the loft (Potterton boiler). My problem is that when the heating is on the expansion pipe intermittantly coughs hot water and steam into the CH tank with such violence that the water is escaping from the tank (and the lid) and thereafter down through my 2nd bedroom ceiling…
I first noticed that the ball valve was ancient, knackered and filling the tank too full, so I replaced it and set the water level to top out around 2 inches below the overflow, leaving around 8 inches of water in the tank. The expansion pipe is about 3 inches above the current water level, but obviously this rises as the pipe coughs more water into the tank, which means that water escapes from the tank as before, and then the level rises until the overflow is called into action, at which point I get a nice outside shower in my garden from the run-off…
Now I thought it might be that the system was overheating, so I turned down the boiler setting from "2" and the thermostat down from 24 celsius (which I didn't think was excessive), but it still does the same thing. As a preventative measure I've tried to silicone seal the tank lid onto the tank so no water can splash over the side in the loft, but this is not exactly a cure...
I'd quite like to stop the coughing, but don't know what's causing it in the first place - any advice? Could it be something as simple as a faulty thermostat that is just letting the heating temp rise and rise, or is there something rather nastier in store for me? All my radiators work fine.
The CH is off until I figure this out. I'm not averse to calling in a pro, but I had the wool pulled over my eyes by my last plumber and would like to be better prepared this time…
Many thanks in advance, and hope I can repay the favour in another area...
BenH
BenH
