DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Parquet Flooring - Color bias in basket weave?
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
JohnandBarbara
from United States of America
Thanked: 0 times
PostPosted: Tue Feb 13, 2007 9:36 pm    Post Subject:
Reply with quote Thanks
I will lay a basket weave pattern in the main field. I would like to have a slight bias in color between the two major directions in the pattern. I notice that in many pictures it appears as if this was an intentional designed element. Is this practical? Would I be better off using two different species such as white and red oak? If I gave half the boards a pre-stain could I achieve the same effect (that would survive sanding)?
Thank you in advance for your help.
Moderator's note:
Welcome to the forums. Please
familiarise yourself with
http://www.diynot.com/forums/viewtopic.php?t=19448
You have posted three times with a similar thing, I will delete the others.
You can use the "edit" button to add text to a post you have already written.
We call this kind of flooring "parquet" so I will add this to your thread title (this is a UK site)
Use this link to look at the Flooring forum http://www.diynot.com/forums/viewforum.php?f=16
Mod Rupert
Thanks for the help.
Although I have laid floors before, I am about to lay my first parquet floor. I am uncomfortable with gluing down 3/4 inch solid wood (over plywood) without mechanical fasteners and/or tongue and groove support. Is this fear justified? I will use strip flooring outside the field. Do I also glue this down?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Tue Feb 13, 2007 10:40 pm    Post Subject:
if gluing one section you should carry on gluing the other to. Be careful using different species of wood. They react to humidity and temperature change different to each other. You may do better trying to get info off an american site to as the rules we fit our floors to may be different to yours due to climate difference.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Feb 14, 2007 11:00 am    Post Subject:
Re: Parquet Flooring - Color bias in basket weave?
Practical? No, optical science my friend. Using one type of wood, say Oak prime (or premium) when installing it in herringbone or basket weave pattern (or many other patterns) will always result in the optical effect as if the fitter has selected light colours for one part of the patterns (or a slightly darker wood type) and another for the other part of the pattern.
But it is all the same wood and not selected on light or dark colouring of the individual blocks. That's the beauty of design parquet flooring!
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Thu Feb 15, 2007 2:49 pm    Post Subject:
Fresh from the camera:
All Oak Prime Grade, all one colour (of course every block has its own character), all optical illusion
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Relaying Square Basket Parquet 2 2460 Tue Sep 18, 2007 3:59 pm
Removing Parquet flooring and leveling 2 220 Sat Apr 11, 2009 9:19 am
Old Parquet flooring 2 160 Tue Apr 14, 2009 8:58 am
Finger Oak Parquet flooring just sanded how best to treat? 5 260 Wed Apr 01, 2009 5:00 pm
Parquet Flooring 6 4160 Wed May 09, 2007 1:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
