dragstar
Joined: 15 Feb 2007 Posts: 9 Location: United Kingdom Thanked: 0 times
Posted: Thu Feb 15, 2007 12:14 am Post Subject: bath removal |
I am replacing a bathroom suite and wanted to remove the bath,so as to do tiling and repairs to the floor and plasterboard.
Could I put the old taps on without the bath so I could turn the water back on?
I was wondering if anyone could advise wether this is a good idea or not.
Dougie |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Thu Feb 15, 2007 12:20 am Post Subject: |
You could do, but it would be better to fit stop-ends or service valves as you are then a bit less likely to have a flood.
Service valves will in any case be handy when you come to install the new bath. You can get full-bore ones which are inelegant with a big lever; but won't show after the bath is panelled in.
The advantage of full-bore over those little ones, is that they won't obstruct the water flow. |
dragstar
Posted: Thu Feb 15, 2007 12:22 am Post Subject: |
Thanks for your reply,
I was thinking that might be a better idea.
Better safe than sorry.
Cheers |
Nige F
Joined: 28 Jun 2005 Posts: 7496 Location: United Kingdom Thanked: 32 times
