Joined: 15 Feb 2007 Posts: 20 Location: West Lothian, United Kingdom Thanked: 0 times
Posted: Thu Feb 15, 2007 12:23 am Post Subject:
leaking boss on soil stack
plz someone help me i recently whilest instaling a new shower tray i acedentlly broke the glued t fitting connected to the soil stack. the t piece was a 4 inch connection that t'd of to a inch and half fitting unfortunatlly it was the inch and half fitting that broke so i cut of the broken peice and drilled a hole in to the t peice to try and resolve the problem with a strap on boss. the boss is now leakng and set fast to the pipe with solvent weld. the biggest pain is the space i have to work with im very hamperd by the amount of space to work with as the pice in qeustion is between to floor joists on the second floor and also as its the stack its away in the corner iv tryed stickinh lots of silicon on it but in one swift swoop all of that came of in one swift pull today as i saw it was still leaking. plz help me is there anything i can do or do i just need to cut and bruise myself trying to cut this pipe and lift it to put a whole new peice in? lmao also running up the stack the mains and hot water pipe and about 6 alarm cables.
oh also the t peice isnt a push fit but is the glued type at both ends
its a big job if i have to replace the walls have been tiled and a vanity unit also hampers my working space
Posted: Thu Feb 15, 2007 1:25 am Post Subject:
ok ill try n get some.
but its a very small leak and i could leave it and it should just fall to the underfloor as the gaps in the floor for the pipe to go down. but thats not right. give me your email ill send pics
Posted: Fri Feb 16, 2007 12:20 am Post Subject:
cheers m8
thanks m8 iv never seen that stuff before i usually do the full works and rip the s**t out and start again with new stuff but as iv already neared completion of this project that happens and its a pure knightmare. but ill try that i think i might try some of that bath fix epoxy thing to if the poly plumb dont work.
Posted: Tue Feb 20, 2007 11:26 pm Post Subject:
well the moment of truth will soon be upon us. after buying some polypipe solvent cleaner, polypipe gap filling cement witch by the way im sure must be banned.
i thought about this alot and decided the best course of action would be to first of all pour to big pans of boiling hot water down the sink and the working the fitting with a hair dryer for over ten minutes. i used the cleaner and then the gap filling cement.
the thing that made me think was that i asked a few plumbers merchants about gap filling cement no one had heard of it and my local supplier whom i most commanly use actually had one half used tube lying around the place somewhwhere so they dug it out for me.
im sure they must have banned this stuff.
the warning on the back said that it may form a peroxide explosive, and also to use away from areas where static discharge may be possible.
the stuff got me out my **** and i had to take about fifteen minutes to recover but it went on like the s**t and it must work i cant see it not.
haha the worst part was it also said give 24 hours before using the pipe again
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
