I have just removed and adjusted the microbore pipe work in my lounge so I can install a small column rad, it is smaller in length and height than the panel rad before it, heating worked great on initial start up, how ever after the removal for decorating purpose the dining room rad on installation the system now has out of 7 rads 2 upstairs warm/hot D/room hot at top cool bottom, Kitchen red hot, hall and bathroom same as D/room, lounge warm at top cool at bottom.
Boiler is Worcester 28CDi, I have drained off through the locksheild drain offs about 4 buckets of water now in case there is a air block in the return system water is very light brown to clear depending on which rad it is, I can\\\'t see these rads sludging up over a couple of days, system was running fine, it is not zoned, HW is ok, pump is working, and have opened the air bleed but just water comes out, all the return locksheilds are luke warm, TRV\\\'s Hot apart from the kitchen rad which works as it should, do you think there is air in the return side of the system. if there is how do I remove it, or should I drain down completely and refill again?
