DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Attaching a new bath to a wall?
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
TMGB
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 9:40 pm    Post Subject:
Reply with quote Thanks
I am installing a new bath, does it need to be attached to the wall or floow to stop it sliding around or twisting when people get in and out (obviously only one person at a time)?
If so, what should it be attached with?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Feb 15, 2007 9:47 pm    Post Subject:
All decent baths come with fixing brackets.
What's the construction of your new bath?
Back to top
 Alert Moderators
solo
from Albania
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 9:52 pm    Post Subject:
Don't fix it to the wall. Use flexi tap connectors and a flexi waste connection, then you can move it about if you fancy a change or just want to clean behind it.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Feb 15, 2007 10:29 pm    Post Subject:
You have got to be kidding.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Thu Feb 15, 2007 10:33 pm    Post Subject:
Reading some of Mr Solo's other posts on here I don't think he is from this world icon_rolleyes.gif
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 11:09 pm    Post Subject:
do you go to the same college as Lorraine by any chance?
__________________
I am newly qualified, so don't rely on my advice get a second opinion!!!
Back to top
 Alert Moderators
solo
from Albania
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 11:15 pm    Post Subject:
Chances are you were still warm sticky fluid when I was at college sunbeam.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 11:23 pm    Post Subject:
I didnt mean to disrespect you Mr Solo..
__________________
Back to top
 Alert Moderators
solo
from Albania
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 11:26 pm    Post Subject:
Moi, kid? Never.
Don't worry bster.....didn't take offence. I've read some of your posts and you could probably blow me out of the water in some matters. It's all just fun.
P.S. Don't tell the others though.
Back to top
 Alert Moderators
Watchmaker
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 11:43 pm    Post Subject:
"does it need to be attached to the wall or floor"
A DIYer comment here. If the bath is a plastic/acrylic type, it is likely to come with some mounting brackets and a pair of support frames. In my opinion, these are never very sturdy and, in time, the bath will move and break any seal or tiling which it might be in contact with. I would suggest a batten on any side which is against a wall, ie, fixed at a height suitable for the moulded lip, of the bath, to rest upon. On the long side, not against a wall, a suitable frame can be made up to sit under the lip of the bath. This will ensure that there is adequate support when this side has to take the weight of a person entering or leaving the bath. A long packing piece, mounted on the floor, under the bath, fitted so that there is a small clearance under the bottom of the bath, will take, and distribute, the weight, when the bath is filled with water. Paying attention to it's rigid installation, at this stage, will avoid various problems later on.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 15, 2007 11:47 pm    Post Subject:
solo wrote:
Moi, kid? Never.
ok
__________________
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Feb 16, 2007 11:02 am    Post Subject:
Gripfill .......solvent based , and inhale deeply icon_eek.gif icon_eek.gif icon_eek.gif icon_razz.gif
Back to top
 Alert Moderators
scooby_snacks
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 16, 2007 11:31 am    Post Subject:
The most common method is to batton to the wall, however I was advised to chase the lip into the wall to ensure a solid fix and water tight seal. You can then run the tiles up to the tub. I've had no end of problems with my bath, thinkin of dragging it out and doing just that... icon_smile.gif
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 6 times
PostPosted: Fri Feb 16, 2007 4:46 pm    Post Subject:
If it is a modern house piece of planed 2x2 screwed into framing and glued (i used no more nails) to the plasterboard - will need cutting away for the bath legs. Two done 18m ago and nothing has moved - one each side of the same wall so it is probably the stiffest wall in the house!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Attaching a towel radiator to a Plasterboard/Stud wall 4 2900 Wed May 02, 2007 11:38 am
Re-attaching a boiler to the wall....(not currently secure) 7 360 Mon Dec 08, 2008 4:14 pm
Attaching fancy shower head to solid wall/ seems too heavy 11 840 Fri Feb 02, 2007 8:53 am
Attaching radiator to wall without using screws 8 300 Mon Oct 26, 2009 11:47 am
Attaching a radiator to a cavity wall 3 540 Wed Aug 11, 2004 1:59 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
