Hot water cylinder
18 Feb 2007
Ive had to remove the hot water cylinder due to the fact of it leaking, i need to get another one obviously, looking on screwfix.co.uk theres direct, or indirect, how do i work out what one i require, as the current one does not say what type it is.
thanks.
i thought id post on here, as ive used the site for advice before. all i need to know is what one to get.( not necessarilygetting one from screwfix)
Details of existing system size of cylinder etc would help you get a bit of help. As not everyone has done the mind reading course
after some googiling im think its a indirect system, because there is a back boiler, as well as the immersion heater.
That sounds very likely!
Last time I looked in B&Q they were about £161 !!! Not long ago they were under £100 !
You need to find out if your system is fully pumped or gravity hot water.
You are meant to convert to a fully pumped system if fitting a new cylinder.
I am not even sure if the current cylinders are designed to work properly on an old gravity system. You must check that if you are leaving it as a gravity system.
Tony
im assuming as there is a pump:
Grundfos
UP5 15-50x18
model C No u610
that it is a pumped system?
its a y? type system i belive also
It may be pumped ! But is it FULLY pumped!
Few older BBUs are!
Do you have a 3-port motor valve ???
Tony
honeywell v4073a1039-7? thats my mid position valve same thing?
