hello my external french doors are sticking between the lead and slave door. the main door when shutting is about 2mm to tight and takes a bit of wedging to get it shut where the two doors meet. can i adjust this to get them in line. any advice would be great.
on a lot of french doors there are allen key adjusters which can be used to wind the door back slightly to stop it catching, or you can toe and heel which means packing the glass, as the door may have dropped slightly.
