DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Planning permission replace flat roof with pitched roof
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
DIYerHELP
from United Kingdom
Thanked: 5 times
PostPosted: Tue Feb 20, 2007 8:59 am Reply with quote
Dear All,
We are planning to replace an existing flat roof over the garage with a pitched roof inline with the existing roof with two velux windows. We have a chalet style house the garage is joined to the house and measures 7m x 2.8m.
The space within the new pitched roof over the garage would be used as an en-suite bathroom.
Would we require planning permission as the existing roofline would be maintained and the volume increase would be height only?
Many thanks for all those that can help me on this matter.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 982 times
PostPosted: Tue Feb 20, 2007 9:35 am Reply with quote
Yes you will almost certainly require PP & BC will want to get involved as well. I had the exact same scenario on an old flat roof extension at the back of my house except we weren’t using the roof space as another room; I just don’t like flat roofs!
You will need to consider the additional weight of the pitch roof & tiles when building/buying the roof trusses & you will need to ensure the insulation of the new room complies with current standards.
Back to top
 Alert Moderators
DIYerHELP
from United Kingdom
Thanked: 5 times
PostPosted: Tue Feb 20, 2007 3:37 pm Reply with quote
Thanks Richard C for you detailed response. I knew BC would be involved but though we could get away without full PP!
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1116 times
PostPosted: Tue Feb 20, 2007 6:48 pm Reply with quote
You could most likely do this under permitted development, and as such will not need a formal planning application.
But check with your local planning office first just to confirm.
Back to top
 Alert Moderators
rangersman
from Australia
PostPosted: Wed Feb 21, 2007 2:15 am Reply with quote
Given the description by the OP I would suspect that planning would not necessarily be needed, provided the plane of the roof was constructed no nearer any public highway, or did not extend above the ridge line.
However, the easiest way is to call the Planner in your area and ask!!
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 98 times
PostPosted: Wed Feb 21, 2007 11:14 am Reply with quote
Normally it's just building regs
Back to top
 Alert Moderators
DIYerHELP
from United Kingdom
Thanked: 5 times
PostPosted: Wed Feb 21, 2007 1:27 pm Reply with quote
Thanks guys for this great help. I'll keep you posted on the outcome.
Back to top
 Alert Moderators
NS215
from United Kingdom
PostPosted: Wed Feb 21, 2007 6:40 pm Reply with quote
i thought you needed PP for any change of appearance
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1116 times
PostPosted: Wed Feb 21, 2007 7:06 pm Reply with quote
No, lots of things are exempt, and other things can be done under permitted development.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Wed Feb 21, 2007 11:31 pm Reply with quote
sorry to hijack, but it is a related question..
would i need planning permission to "square off" a roof?
what i mean is, i have a flat with a 3 sided roof ( see picture ) and would like to develop the loft space at some point, making the roof only 2 sided for added space.. ( my flat is top 3 windows on the right side.. want to make into gable end with window perhaps.. )
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1116 times
PostPosted: Thu Feb 22, 2007 12:45 am Reply with quote
Yes you would need permission, and from a planning/design perspective your proposal would unbalance the terrace, and so you would have a job getting permission
Back to top
 Alert Moderators
rangersman
from Australia
PostPosted: Thu Feb 22, 2007 6:28 am Reply with quote
I would suggest that there is a case for not needing PP for this work as the roof projects no closer to the highway, or extends above the exisitng ridge. This guy's didn't:
http://www.internode.co.uk/loft/index.htm
Are you the freeholder though? That could stuff up the plans maybe!
As always though - go in and ask the LPO!
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1116 times
PostPosted: Thu Feb 22, 2007 11:03 am Reply with quote
I don't know of any of these locally, where the various councils have accepted these under permitted development.
A very recent case in Sandwell, made headlines where a rear dormer was built without permission (lower than ridge, no near to highway etc), and yet it has been determined to have required permission - something which was refused on application and on appeal, and now it is subject to an enforcement order and has to be removed.
I would suggest a written reply from the council confirming that no PP is required, or a Certificate of Lawful Development application would be the best course of action.
Back to top
 Alert Moderators
DIYerHELP
from United Kingdom
Thanked: 5 times
PostPosted: Thu Feb 22, 2007 2:29 pm Reply with quote
Good advice Woody cheers!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Converting a garage and a flat roof to pitched 3 300 Sun Mar 13, 2011 10:48 am
tiling pitched roof with a flat bit 2 700 Mon Mar 24, 2008 9:50 pm
Lateral force of Roofing sheets on a pitched flat roof. 9 1080 Sun Apr 18, 2010 7:25 pm
timber pitched roof/ceiling insulation underside design. 4 640 Tue Dec 09, 2008 4:23 pm
Can I use pitched roof insulation under floors? 2 380 Sat Jan 24, 2009 8:29 pm
DIYnot
