DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
!!!!! HELP!!!!!! Convert 1 way switch to 2 way switch
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
AndrewL
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 22, 2007 1:50 pm    Post Subject:
Reply with quote Thanks
I have a light switch in my living room when truned on it turns on both lights.
I want to put a 2 way switch so each light can work independantly...
There seems to be 2 red wires going into one opening and one black wire which goes into the other.
Anyway idea how I can change this into a two swtich?
Andy
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dw3101
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 22, 2007 3:01 pm    Post Subject:
You can hope that the black is the incoming live and it should have red/brown sleeving on it, and if it is then loop this between each 'com' terminal and then move the two reds each to l1
However I suspect Black is in L1 and the others are the Live in and out..
If that is the case then I'd just live with it.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Thu Feb 22, 2007 3:19 pm    Post Subject:
can i point out that what you want to do is 2 GANG, from 1 GANG, not 2 WAY from 1WAY..
2 WAY is one switch somewhere and another somewhere else that both turn on the same light ( or group of lights )
Back to top
 Alert Moderators
AndrewL
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 22, 2007 4:03 pm    Post Subject:
Hi ColJack,
Yes, sorry what I mean is I want to change to a 2 GANG from a 1 GANG....
Cheers
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Thu Feb 22, 2007 10:59 pm    Post Subject:
As the others have implied, you may find that the two reds are live in & out, with only one switchwire (the black). In which case, to switch them independently, you need to run another wire from one of the fittings down to the switch.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Confusing switch wiring and convert one-way to two way 6 3520 Fri Nov 16, 2007 6:43 pm
Convert 1 way light switch to 2 way? 6 540 Fri Dec 29, 2006 8:57 am
Convert light switch into plug socket for plinth lights 11 2040 Thu Aug 21, 2008 12:13 pm
Convert a three way switch back to two 10 2020 Mon Aug 29, 2005 12:53 pm
Convert 1 way to 2 way 2 400 Tue Apr 03, 2007 6:49 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
