DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Warmup Underfloor Heating Connection
Author Message
billau
from United Kingdom
PostPosted: Fri Feb 23, 2007 10:03 am Reply with quote
I need to connect my warmup underfloor heating, I have the themostat installed and connected to the heating cable and from the thermostat wiring goes into the loft. I did it this way as there was already t&e wiring from under the floor to the thermostat location which was previusly used for a fan heater, now disconnected.
Problem is in the loft the only mains power source is a double 13 amp socket which is spurred from the ring main downstairs. Can I simply connect the thermostat via a JB to a 13 amp plug and plug it in or am I being really stupid? Do I need to spur into the ring main from somewhere else?
Back to top
 Alert Moderators
summo
from United Kingdom
PostPosted: Fri Feb 23, 2007 11:02 am Reply with quote
I have a similar product and believe it needs to be connected via its own circuit breaker, not via your sockets.
Back to top
 Alert Moderators
tekkiesteve
from United Kingdom
PostPosted: Fri Feb 23, 2007 12:39 pm Reply with quote
why don't you forgo the socket in the loft and replace it with one of these http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A231858&ts=34145&id=14770
steve
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 46 times
PostPosted: Fri Feb 23, 2007 12:57 pm Reply with quote
The normal questions are:
Rating of heating element/s you are trying to connect?
Cable size / protection device for circuit you want to connect it to?
Any manufacturers instructions?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 457 times
PostPosted: Fri Feb 23, 2007 9:19 pm Reply with quote
You should follow the mfrs instructions. Having installed Warmup, you need RCD protection first off.
You also need the controller to be accessible. This isn't going in the loft, is it??
Do you mean you have broken into the thermostat cable and extended it with T & E?? Is that OK as per the instructions?
If in doubt RING THE MANUFACTURER!
Back to top
 Alert Moderators
billau
from United Kingdom
PostPosted: Fri Feb 23, 2007 9:26 pm Reply with quote
Thanks for the replies, it's a 400 watt heater, 1.7 amps and must have an RCD. The house fuse box has an RCD. The thermostat is installed on the landing outside the bathroom and I connected the thermostat using T&E to the heating element. Then there's T&E from the thermostat up into the loft.
I have discovered mains power in the loft for the central heating pump, would it be best to spur from this with a 30amp JB. I assume spurring into the lighting circuit is a no-no.
Back to top
 Alert Moderators
ELZ4742
from United Kingdom
Thanked: 16 times
PostPosted: Sat Feb 24, 2007 6:38 am Reply with quote
the central heating pump will not be a permant feed, only on call, so this aint much good tya.
Back to top
 Alert Moderators
billau
from United Kingdom
PostPosted: Tue Feb 27, 2007 12:39 pm Reply with quote
I never go this far as a test shows some problem with the heater element. It was working OK during and just after tiling, now when I connect up directly to the mains (thermostat not wired at this point) using a standard plug - which is Warmups' recommended way of testing the heater - it trips out the house fuse box. Warmup will send an engineer but not until April!
Anyone any ideas meantime?
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Warmup Underfloor Heating Install, advice please (with pics) 15 2380 Tue Nov 03, 2009 5:08 pm
Warmup XSTAT U/F Thermostat - Identify Sensor? 8 140 Mon Dec 23, 2013 9:26 pm
Warmup Second slave thermostat possible? 11 200 Wed Mar 27, 2013 6:35 pm
Warmup XSTAT Wiring Advice - Loose Wire System 2 1080 Fri Jun 27, 2008 3:42 pm
Warmup time of CFL GU10's... what about LEDs? 8 840 Thu Apr 23, 2009 11:16 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
