DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Gas meter on flexible connections?
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sat Feb 24, 2007 6:58 pm Reply with quote
I have a gas meter in the kitchen I am doing up, it is located on the floor in the corner in what used to be a brick cupboard.
It has a lead pipe comming form the supply side pipe to the meter that is badly bent and crimped..
The floor of the cupboard is slightly higher than the rest of the kitchen and i wanted to grind it down before leveling the whole floor..
what I could do with is getting the gas suppliers out to either move the meter off the floor onto a bracket or something, or having it on some sort of flexible connection (as on the outlet side of the meter ) so I can raise it up to floor under it and then put it back down..
Is this a posibility or will they just tell me to go away?
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 408 times
PostPosted: Sat Feb 24, 2007 7:05 pm Reply with quote
Flexibels (even hose pipe)? I DO NOT think so. But no harm in asking.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 79 times
PostPosted: Sat Feb 24, 2007 7:12 pm Reply with quote
National Grid will move your meter for you (outside if you wish) if you have a few hundred quid to spare. icon_sad.gif
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Sat Feb 24, 2007 7:33 pm Reply with quote
first time iv'e seen an anaconda on the outlet side icon_confused.gif icon_confused.gif
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 491 times
PostPosted: Sat Feb 24, 2007 7:36 pm Reply with quote
Looks like you have a very old connection. lead is ok except in blocks of flats. Can't quite see what type of govenor you have. Does it sya Jeavons J88 on the label on the top? If so these have to be replaced when discovered. If it is a J88 call Transco and tell them you have been told you may have a faulty govenor. If it is a J88 they will replace it and you will get a new flexible anaconda pipe from your ECV to the new govenor as well. All FOC!
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 491 times
PostPosted: Sat Feb 24, 2007 7:38 pm Reply with quote
Quite common in my area, although I always change them when any gas work carried out on pipe work.
Back to top
 Alert Moderators
baxpoti
from United Kingdom
Thanked: 552 times
PostPosted: Sat Feb 24, 2007 7:45 pm Reply with quote
Is that a hit and miss vent, supplying an open flue appliance?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sat Feb 24, 2007 7:51 pm Reply with quote
that's just what i found when i took the units out.. used to be a cupboard there at some point (hence the hole in the floor where the wall was. ).
there are vents all over the flat.. one in the bathroom ( now housing the extract fan ) and one in the "spare" room also..
the boiler is above that gas meter so extra fresh air is doing it no harm..
just gotta make the unit i put it back into draught proof..
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 491 times
PostPosted: Sat Feb 24, 2007 8:01 pm Reply with quote
If baxpoti is correct and this is a vent for an open flued appliance then it should be made permanently open and any fly screen removed. Also in this case DO NOT make it draught proof unless other permanent vent is fitted elsewhere
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2525 times
PostPosted: Sat Feb 24, 2007 9:49 pm Reply with quote
I read somewhere that an anaconda on the outlet of a meter is NCS and should be removed when possible.
If its acceptable on the inlet I dont see why its not acceptable on the outlet. Hard piped connectors on the outlet could get strained by anyone abusing the gas meter and the pipework might start to leak!
Tony
Back to top
 Alert Moderators
keego
from United Kingdom
Thanked: 62 times
PostPosted: Sat Feb 24, 2007 10:19 pm Reply with quote
I think a meter on 2 flexi's is NCS only for the fact it make's it easier for the user to fiddle the meter!
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 936 times
PostPosted: Sun Feb 25, 2007 8:46 am Reply with quote
The National Grid man should want it fixed to the wall, unless it's firmly on the floor which you don't want.
Needs an Earth Bond too.
Let a corgi at the outlet side pipe and you're likely to be told it can't be altered unless all the pipework is changed because it's undersized. It's nearly always undersized.....
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2525 times
PostPosted: Sun Feb 25, 2007 11:52 am Reply with quote
Since its National Grid who should have fixed it to the wall in the beginning its unlikely any of them will want the bother.
I have twice reported to Transc that the meter is not fixed to the wall and just hanging off its pipes at high level and they only VERY grudgingly came and sorted it out!
Tony
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 491 times
PostPosted: Sun Feb 25, 2007 11:54 am Reply with quote
I queried this with my CORGI inspector and he said tha it is fine with one each sideof the meter. What was meant is that 2 flexis joined together for extra length is not allowed.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2525 times
PostPosted: Sun Feb 25, 2007 12:05 pm Reply with quote
I dont think he gave you the correct "official CORGI answer".
There is nothing unusual about that of course!
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 4
Jump to:
Flexible hose for radiator connections 4 2380 Fri Jan 08, 2010 10:18 am
Leaky flexible tap hose connections! Help! 15 1200 Wed May 06, 2009 4:01 pm
Who's responsible for the connections to the water meter? 7 620 Tue Jul 21, 2009 10:51 pm
2 flexi connections from meter 16 1121 Sun Dec 20, 2009 9:37 am
flexible connection to the gas meter? 36 5920 Sat Nov 13, 2010 12:52 pm
DIYnot
