DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
RAZOR SOCKETS
This topic originated from the How to page called Adding a spur to a ring circuit from a junction box
Click here to return to the page called Adding a spur to a ring circuit from a junction box.
  View previous topic :: View next topic
Author Message
CLIFFORD MITCHELL
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 27, 2004 12:22 pm    Post Subject:
RAZOR SOCKETS
Reply with quote Thanks
I HAVE AN EX GUEST HOUSE APPROX 70 YEARS OLD. IN EACH ROOM THERE IS A RAZOR SOCKET (OF WHICH ONLY TWO ARE USED). I WANT TO KNOW IF I CAN CONVERT THESE RAZOR SOCKETS INTO POWER POINTS AND IF I CAN THEN SPUR OFF TO PROVIDE ADDITIONAL BOXES. THE FUSE RATING FOR THE SHAVER POINTS IS 15AMPS. ALL OF THE SHAVER POINT WIRES CONNECT INTO A JUNCTION BOX WHICH THEN GOES TO THE MAIN JUNCTION BOX AND THEN TO THE DISTRIBUTION BOX.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Mar 27, 2004 12:25 pm    Post Subject:
no, and please don't SHOUT
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Mar 27, 2004 9:52 pm    Post Subject:
I'll whisper then, to balance it.
If (as it could be from the description) it's a multi-legged radial circuit, wouldn't the OK/not-OK verdict depend on the size of cable used and the floor area served?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Mar 27, 2004 10:10 pm    Post Subject:
yes but the poster said ALL OF THE SHAVER POINT WIRES CONNECT INTO A JUNCTION BOX which would imply it is neither radial or ring but "spider"
__________________
Forum = Opinions
Back to top
 Alert Moderators
AdamW
from Vatican City State
Thanked: 0 times
PostPosted: Sun Mar 28, 2004 1:06 pm    Post Subject:
I think the fact that there is a dedicated shaver circuit explains it all: Seeing as a shaver draws what, 5 watts? This circuit was never intended to power 13A devices. If used as such it would probably trip/fuse all the time and cause you more headaches than it is worth anyway.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Garage sockets, how to use 6mm cable? 10 600 Wed Jan 09, 2008 11:03 am
Sockets halfway up the wall? 6 500 Fri Jan 18, 2008 11:42 am
Installing additional sockets 22 960 Tue Jan 08, 2008 8:25 pm
Sockets in loft for shower pumps 9 420 Sun Jan 06, 2008 11:11 am
Failure rate - MK sockets? 7 800 Thu Dec 20, 2007 10:50 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
