DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing ceiling rose with spotlight bar
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
lloydg
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 12:16 pm    Post Subject:
Reply with quote Thanks
I have just bought a 3 halogen bulb spotlight bar and the instructions say to fix each of the wires from my supply into the live, neutral & earth connectors on the spotlight fitting, however when I have removed my old ceiling rose I have 3 cables coming from the ceiling each with one of each (live, neutral & earth) wire with one of the black wires covered in a red sleeve (the switch?) How do I wire all of these cables into the single connector on the new spotlight. Also having removed the old ceiling rose none of my lights on the same fuse work!! Have I blown something? The curcuit breaker is still on. HELP!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 25, 2007 12:28 pm    Post Subject:
Don't panic
See
http://www.diynot.com/forums/viewtopic.php?t=7553
The three red wires need to be joined together in a separate terminal block. which you will have to supply if the fitting only has three.
Of the three reds.. One is feed from the fuse, one is feed to other lamps ( hence they don't work ) and one is down to the switch.
The two black wires go to the neutral of the new fitting. One is neutral from fuse and one is neutral to other lights.
The black wire with sleeve goes to the live of the fitting ( this the switched live coming back from the switch.
All the three earths MUST be joined together and connected the the earth of the fitting.
Back to top
 Alert Moderators
lloydg
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 1:14 pm    Post Subject:
Thanks for that! Forgot to mention that the light is controlled by two switches (as its on the top of the stairs) but there is only one sleeved wire. Does this change what you have said? Also, you mention a separate terminal block for the three red wires - obviously the three wires go into one side of the terminal block, but does a single wire have to come out of the other side into one of the points on the light fitting? All of this and the instructions said 'as long as you can change a plug, you can fit these lights!!!' Oh well! Thanks again
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 25, 2007 2:18 pm    Post Subject:
No as the switch wiring is between the switches and the black woth sleeve will be the only wire from the switches.
Only the three reds go int othis block. Nothing else.
You can put two in one side and one in the other if that makes it easier to wire.
NO the fitting only has the neutral from the two blacks, the switchd live from the black with sleeve and the earth.
Thats a sales gimmick. They should supply clear diagrams and include that extra necessary terminal block.
Back to top
 Alert Moderators
lloydg
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 01, 2007 12:12 pm    Post Subject:
Three more questions...... 1. What amp terminal block should I use (the circuit breaker says 6A for my lights). 2. How do I extend the wires coming from the ceiling as the existing ones are not long enough to allow me to connect them to the new fitting. 3. Can I do something temporarily to get the rest of my lights working?
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Thu Mar 01, 2007 1:15 pm    Post Subject:
[1] 10 amp is probably the best.
[2] use a 4 way terminal block to terminate and connect the cables. Then run a length of new cable from that to the lamp fitting.
[3] Using a 4 way terminal block
connect all earth wires together. terminal 1
put the black with sleeve into terminal 2 by itself
put the other blacks together into terminal 3
put all the reds together into terminal 4
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Mar 01, 2007 5:14 pm    Post Subject:
Other (easier) option, chnage the flex from the rose to a 3 core, fix new light to ceiling, spacing it off, and connect flex to new light.
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Thu Mar 01, 2007 5:19 pm    Post Subject:
That is by far the best way. But too simple....
But has the great advantage that when cost of replacing the halogens becomes too much then putting back the simple hanging lamps is so simple.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
removing a ceiling rose and fitting a spotlight fitting 3 860 Wed Jul 06, 2005 10:29 am
ceiling rose to spotlight help - neutral wires 2 300 Sat Jun 21, 2008 3:22 pm
replacing standard ceiling light with multi-spotlight 5 480 Sat Apr 26, 2008 7:46 pm
Ceiling spotlight faulty but works when not in its housing 4 520 Sun Sep 17, 2006 9:16 am
Newbie question - wires too short for ceiling spotlight! 20 1080 Tue Mar 30, 2004 1:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
