DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Monoblock Kitchen Mixer Tap Spout Problem
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Neil_And_His_Spanner
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 6:49 pm    Post Subject:
Reply with quote Thanks
Recently had a new kitchen fitted with the following monobloc rotating spout mixer tap installed:
http://www.clickbathrooms.co.uk/pd-TAPKC012.htm
Moving the spout currently causes the whole monobloc to rotate which then loosens the nut under the sink which holds the whole bloc in place. Looking at it I think what should happen is the spout should rotate independently of the central piece of the column which is jointed just above where the spout joins the central column. Tightening the nut under the sink just causes the circlip/washer thing to start to buckle, and eventually the whole thing works loose again as you move the spout around. Can't find a tech drawing of the tap innards to work out what to fix/hit with hammer etc. Any suggestions welcome, 'cos it's doing my head in!! cheers NahS icon_rolleyes.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 25, 2007 6:52 pm    Post Subject:
call the kitchen fitter/ installation compny back, its not your problem, but it wil be if you break it
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Can\\\'t remove mixer Spout 3 2480 Sat Feb 04, 2006 3:54 pm
Bath mixer taps with shower - no flow from spout? 2 260 Wed Dec 17, 2008 9:18 pm
Monobloc Mixer tap spout is stiff to swivel 2 1700 Sat Oct 14, 2006 1:48 pm
Separate Taps and spout - help... 4 400 Mon Feb 04, 2008 7:45 pm
loose tap spout 4 1740 Wed Feb 15, 2006 9:23 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
