DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Connecting a Shaving point
This topic originated from the How to page called Installing a Shaver Socket
Click here to return to the page called Installing a Shaver Socket.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
drewball
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 26, 2007 2:12 pm    Post Subject:
Reply with quote Thanks
I would like to install a shaver point in my bathroom. I understand I would need to have a shaver point with a transformer to put it in the bathroom.
The question really is can I make a spur from my switch for the boiler? This is situated in the airing cupboard. (Switch has a light to determine if its on or not). If so would i need to have this put into a fused switched unit or straight to the shaver point.
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Feb 26, 2007 10:09 pm    Post Subject:
What circuit is the boiler spur fed off, and with how many cables of which size?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
sinewave
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 06, 2007 4:59 pm    Post Subject:
shaver point
Do not connect the unit direct from the boiler supply, you need a switched fused unit with a 3 amp fuse fitted,
Connect your shaver unit which is isolated to say your lighting circuit and use a 3amp fuse in the fcu.
Back to top
 Alert Moderators
sinewave
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 06, 2007 11:56 pm    Post Subject:
shaver point
Hope you got your shaver unit fitted safely, forget the boiler and how many cables /thickness as suggested by another.
These shaver units do not draw current in amperes more like mA.
Shaver units also incorporate a safety fuse internally.
Back to top
 Alert Moderators
equitum
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 07, 2007 8:24 am    Post Subject:
Most boilers are fused at 3A in the FCU (or should be), whats the issue with taking the feed from here provided total load of boiler + shaver cct does not exceed 3A ?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon May 07, 2007 11:04 am    Post Subject:
Providing the boiler ckt is included in the supplementary eq. bonding arrangement and is from a 3A FCU, probably not that much of an issue. The legal side re. Part P notification may be an issue though.
Back to top
 Alert Moderators
equitum
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 07, 2007 11:10 am    Post Subject:
Sorry not following the legal bit, why are the part p requirements any different in this case than any other work in a special location ?
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon May 07, 2007 11:12 am    Post Subject:
CR@P design feeding it from the output of the spur - utter cr@p. What a s***te DIY install that would be.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon May 07, 2007 11:18 am    Post Subject:
Yeah, I agree. Better fed from the lighting circuit.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Mon May 07, 2007 11:23 am    Post Subject:
Lectrician wrote:
c**p design feeding it from the output of the spur - utter c**p. What a s***te DIY install that would be.
Even worse if it was done on the say -so of professional advice
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon May 07, 2007 11:24 am    Post Subject:
No different, only as a DIYer I doubt they are a member of a competent person scheme hence should go the building notification route i.e. notify LABC and pay their fee before starting work if they should wish to remain within the law.
Back to top
 Alert Moderators
equitum
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 07, 2007 5:41 pm    Post Subject:
I agree its not the best design or preferable over other options, but never the less was interested as to the reasons being stated for not using the boiler circuit, whether regulatory or otherwise.
Back to top
 Alert Moderators
swinster
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 09, 2008 3:12 pm    Post Subject:
Just a question on this old thread, if you connect to a lighting circuit (say at the ceiling rose), then where would place the 3amp switched fuse?
For info, the shaver socket intended for use uses a "safety overload cut out device"
Back to top
 Alert Moderators
kkynaston
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 09, 2008 9:24 pm    Post Subject:
between the light fitting and the shaver point
__________________
He's not the Messiah! He's a very naughty boy!
Back to top
 Alert Moderators
hairyben
from Morocco
Thanked: 0 times
PostPosted: Tue Dec 09, 2008 9:28 pm    Post Subject:
You don't need to fuse down if coming off a lighting circuit.
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
replacing shaving point in bathroom... 2 440 Fri Jun 29, 2007 8:16 pm
Humming noise from shaving point 10 320 Wed Jun 24, 2009 12:25 pm
Flourescent shaving light premanently warm 4 240 Thu Jul 31, 2008 11:46 am
Shaving sockets and Part P 3 260 Sun Nov 30, 2008 10:15 am
Shaving socket from boiler 5 280 Sun Feb 03, 2008 12:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
