Ok this one has obviously flumoxed you all. I think the problem is the pump, it's making a humming noise but not apparantly pumping. Next question is how do you open the door? The CPU is keeping it locked as its full of water still. I've tipped it back 45° but the door is still staying locked. Any ideas...?
Turn the machine off and leave for 2-3 minutes and the LOCK mechanism will release. Make sure you tilt the machine back to prevent the load water ****ing out all over your kitchen.
Counting from the top (top light being 1) which lights are flashing?
Take the drain hose out of the standpipe or off the spigot and lower it into a basin, drain the water out of the machine then you'll be able to open the door without fear of flooding.
Thanks but I've solved the problem now (lamps were 2nd and 3rd from top). I removed pump from hose assembly and found a nice red elastic band wrapped around the prop (thanks Royal Mail). Just giving it a wash test now but don't anticipate any more problems.
Glad you sorted it. Sorry I missed your post earlier. If any other problems post the numbers of the flashing lights on the left hand side and I'll let you know what they mean.
