DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Lights not working - no fusebox problems
This topic originated from the How to page called Types of electrical circuits
Click here to return to the page called Types of electrical circuits.
  View previous topic :: View next topic
Author Message
Scotty14
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 28, 2007 1:49 pm    Post Subject:
Reply with quote Thanks
A light blew in our utility room and I replaced the bulb accordingly. Still no lights at all in this room - checked the fusebox and nothing had tripped.
There are now two roof lights not working (usually from the same switch) and the toilet light (different switch). Guessing that they are obviously on the same circuit - any ideas on whats wrong - greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Wed Feb 28, 2007 1:59 pm    Post Subject:
With the power switched off you will need to look in the ceiling rose for each light, I would suspect that there will be a loose connection on either the live or neutral that loops from one light to the next. If you cannot see an obviously loose wire, then you will need to be able to test for voltages, preferably with a multi-meter. I would suggest you start with the one closest to the consumer unit. Alternatively if there are only switched live & neutral in each ceiling rose you will need to find junction boxes or connectors in the switch boxes.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
fusebox problems? any ideas? 3 2020 Thu Feb 23, 2006 2:21 pm
Fusebox - loose connection on busbar and mcb 37 3260 Sat Mar 24, 2007 1:50 am
Age of fusebox 10 620 Wed Mar 07, 2007 6:21 pm
A quick look at my fusebox? 14 980 Sun Apr 29, 2007 8:44 am
Replacement of house fusebox with new MCB 11 2920 Mon May 07, 2007 8:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
