beckmeghan
Joined: 28 Feb 2007 Posts: 3 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Wed Feb 28, 2007 4:28 pm Post Subject: Smoke through wall |
Help! We have quite recently had new neighbours move in next door to us. We live in a semi and they are attached to our house. They are Turkish and smoke very strong cigarettes. Unfortunately the smoke is somehow coming in through the wall into my 7yr old daughters bedroom. I have no idea how it is coming in, we've not had this problem before! I have bought an air purifier which helps but other than that I am at a loss as to what to do. Any ideas? |
noseall
Joined: 02 Feb 2006 Posts: 11053 Location: Staffordshire, United Kingdom Thanked: 71 times
Posted: Wed Feb 28, 2007 6:10 pm Post Subject: |
do you live in a terraced house with no loft separation? |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Wed Feb 28, 2007 11:29 pm Post Subject: |
The walls are (presumably) plastered where they are on show; but above the ceiling and below the floor there may well be gaps and open cracks that have not been filled. You can clean these out and fill with mortar (it will also reduce sound transmission) or expanding plastic foam (which is very messy).
If there are old fireplaces then the wall between them may only be half a brick thick and cracks are quite common on the chimney wall. |
beckmeghan
Posted: Thu Mar 01, 2007 9:14 am Post Subject: |
We live in a semi - my husband has been up in the loft and checked it out, apparently there was no smell of smoke up there at all. |
Paul_GPvR
Joined: 16 Feb 2005 Posts: 71 Location: United Kingdom Thanked: 0 times
Posted: Thu Mar 01, 2007 10:10 am Post Subject: |
coming in through any air bricks or vents ? |
JohnD
Posted: Thu Mar 01, 2007 10:46 am Post Subject: |
look for cracks in the wall under the floor.
Or at a chimneybreast/fireplace
How old is your daughter? She blames the smell of cigarettes on the neighbours?  |
beckmeghan
Posted: Thu Mar 01, 2007 12:40 pm Post Subject: |
Daughter is only 7 so unless she's started very early .... |
