nmit
Joined: 01 Mar 2007 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Thu Mar 01, 2007 1:24 pm Post Subject: replacing existing switch with dimmer - confused about cabli |
Hi.
I recently moved house and thought I would replace the light switch in one room with a dimmer switch. I have done this in a previous house and it was straightforward so didn't anticipate any problems.
However, when I opened the existing connection - I'm a little confused about the cabling and hoped someone could explain?
I was expecting to see one red wire (L1) and one black wire (L2) which I would just replace into my new dimmer switch.
Instead I see 2 red wires connected. The terminals are labelled "Top" and "1" and "2" and then at the bottom just "1" and "2"
One red cable is connected to "1" at the "Top" and the other red cable is connected to "1" at the bottom.
(There are black cables but these are not terminated on the existing switch. And there is a green/yellow earth at the back)
My confusion is - which red cable do I connect to which terminal on my new dimmer switch?
Can anyone help? (I thought it best not to do anything further until I'd checked with the experts!)
Thanks. |
securespark
Joined: 11 Jan 2004 Posts: 16491 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Thu Mar 01, 2007 1:39 pm Post Subject: |
Are there just two wires connected to the switch?
If so, connect as advised in your dimmer's instructions. __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
nmit
RF Lighting
Joined: 31 Mar 2006 Posts: 10753 Location: Birmingham, United Kingdom Thanked: 73 times
nmit
Posted: Thu Mar 01, 2007 9:00 pm Post Subject: |
Thanks very much, that seems to have worked a treat! (I was just a bit nervous about doing anything before I'd checked it out as the cables weren't as I had anticipated to start with!) |
