DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
fitting exterior door frame
This topic originated from the How to page called Fitting the new exterior door frame
Click here to return to the page called Fitting the new exterior door frame.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
NickStone
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 02, 2007 8:33 pm    Post Subject:
Reply with quote Thanks
Your instructions say 'replace the damp proof course' if damaged. How does one do this, please?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Richard C
from United Kingdom
Thanked: 49 times
PostPosted: Sat Mar 03, 2007 4:12 pm    Post Subject:
Re: fitting exterior door frame
Who's instructions; which damp proof coarse; is the frame timber or plastic?
__________________
Richard C
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Sat Mar 03, 2007 5:18 pm    Post Subject:
What they mean is when taking out the old frame, sometime the dpc get damaged as most of the door frame do rest on the dpc, if it's damaged then put down some bitumen product over the damaged area then a new strip of dpc on top.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
NickStone
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 03, 2007 10:41 pm    Post Subject:
>>>Who's instructions; which damp proof coarse; is the frame timber or plastic?<<
The instructions for replacing a door frame on the DITnot.com site, Richard. The frame is (I think)UPVC.
Back to top
 Alert Moderators
NickStone
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 03, 2007 10:44 pm    Post Subject:
Masona, that sounds good. Bitumen I think I can find in the flat roofing product section of B & Q. But I've no idea where to get the strip of dpc. Are there different brands? Thank you.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 49 times
PostPosted: Sun Mar 04, 2007 10:14 am    Post Subject:
Masona's got it, put a new strip of DPC over the top of the damaged one. DPC comes on a roll, it’s like a black dimpled plastic strip around 100mm wide, you can get it at any DIY store or builders merchant; fix it in place over the old one by applying a bead of silicone down each side. You can also use a liquid DPC, just paint on at least 2 coats – “Seal Hyprufe” is one I’ve used on larger floor areas but it’s a bit expensive.
__________________
Richard C
Back to top
 Alert Moderators
NickStone
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 05, 2007 9:59 am    Post Subject:
That's great, Richard. Thanks a lot.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Exterior door frame question 2 4260 Mon Jun 19, 2006 2:21 pm
Replacing an exterior door with an interior one. 4 520 Thu Feb 21, 2008 6:47 pm
PVC Exterior Door Panel 2 420 Sun Mar 23, 2008 6:31 pm
john carr exterior door lock 4 660 Fri Aug 03, 2007 9:19 am
Sills and seals for a custom made exterior door 2 820 Tue May 15, 2007 12:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
