Sanding walls - too smooth?
5 Feb 2007
Lincolnshire
Hello,
I'm currently redecorating the living room and want to re-paint the walls. Like the previous owner, I am going to paint directly on the plastered wall, i.e. not using lining paper.
This may be an odd question, but when it comes to sanding the wall down, is it possible to make it too smooth? On a small patch I used a coarse P80 paper followed by some medium (P120 I think) wet&dry paper (used wet) which produced a really nice smooth surface. Before I do the rest of the room like this, however, I would like to know whether I may end up making the walls too smooth to apply the paint effectively? I'm planning on using a roller, for which I would imagine a slightly rougher surface might allow better coverage.
Thanks for your help
Russ
Are you saying you are painting onto bare plaster?..
Dont rub it down with anything you will scratch it to pieces
No, the walls are plastered but have been painted several times already. I will be only be sanding back the existing paint.
Ta
R
I doubt if you will make the walls so smooth they wont take the paint but you may be going overboard with the rubbing down...
You will find that when you re paint you will put back some of the surface due to the fact that emulsion dries very quicky
If you really want a good quality finish now id suggest you brush it...if you use a roller all your hard work will be in vain
lightly sand walls wipe clean and paint. If walls have been painted before no problem.
if any check sometimes oil paint and latex won't stick or bond.
crazy canuck
ps what is this lining paper i keep hearing about don't have the word in canada.
It's a plain cheap wallpaper that's used for covering rough walls before painting or putting up your finish wallpaper. It comes in different thicknesses depending on how bad the walls are.
crazy canuck
You might call it base paper or backing paper over there
Thanks for your help guys,
I think I'm going to opt for the LIGHT sanding option!
Other than sanding and more sanding does anyone have any particular tips on how to get rid of brush marks? The person who lived here last has left heavy brush marks in all the corners where she tried to do the cutting in.
Cheers
R
